Bousez
- Jan 22, 2012
- Riviere Beaudette, Quebec, Canada
- www.riviere-beaudette.com
We want to install a rear radiator on my son's Viper .....
Apparently a rad from an SRX would fit bolt-on ...... ? can someone confirm ?
What about a 700Sx radiator ?
snoprokidf6
srx will bolt, right in, you have to remove 4 rivets, pull back the tunnel cap a bit and slide it in, then drill several holes and one for the bleed screw and you're done
I have a rear cooler and protectors if you are interested. PM me...
Bousez said:We want to install a rear radiator on my son's Viper .....
a 700sx cooler will work, they are much better then stock cross tube and lighter. However... the hose size is smaller on the sx sleds. What i have done in the past when using the sx cooler was to use 3/4" heater hose, make 2 small peices to slip onto cooler then force the viper hose on over top of that, use double clamps and they are fine.
the srx cooler is a bolt on deal as mentioned, same size hose ends as a viper as well. the srx cooler holds more coolant and is larger in size, will cool more if triple piped,big bore, etc. but its heaveier as well. so youll have to pick which way to go is better for you..
Bousez
- Jan 22, 2012
Thanks Mr Viper
I'll look for an SRX cooler !
I'll look for an SRX cooler !SXViperGuy
YESS it will fit i put an SRX Radiator on my Viper it fitss.
Bousez
- Jan 22, 2012
good to know, i might have found one for 50$
SXViperGuy
Ya i think i got mine for like $100 or something like that so yea check it out before you buy it so theres nothing wrong with it that you can see on the pictures if your buying it on the internet.
