1998 srx 700 power valve set up
smittysrx700
rhode island
does anyone have info on setting power valves without starting the motor? can i run 12 volts to the servo if i disconnect the plug? which wire do i run 12v to? and what color to ground? just had pv's out for cleaning. also just dropped motor back in after installing new steering shaft and new seals in water pump. this blue beast has 8500 mi. on it and still runs awesome! thanks guys, great site!
Just tighten the adjuster bolts all the way forward (loose) start it up and use the choke to idle it down below 900rpm and the servo wheel will turn counter-clockwise. Make a mark and perform adjustment. For some reason the 98's dont stop the postion on the servo. I tried it once and it just stretches the cables, it turns forever with power applied.
pv ajustment
thanks motorhead 327 for quick response to p/v adjustment/setup. can you send some snow this way? been a lame season!!!
