Bravo hand grips
Yamahasrx700
Channaho, Il.
I am in the wrong forum but I want someone to see this. Has anyone put heated handgrips on a Bravo? My little girl would love a set on the Bravo
should not be an issue.I put heated handgrips on an old 76 Pantera years back.Only thing is the power out put may not be sufficient .But I hooked mine up with a toggle switch with low/high.They did work some..You have to get the right epoxy to glue them on also..can be done.Instructions are usually in the pkg..comes with everything you need..
