GBW
2001 700 SXR. Was told removing middle layer of head gasket caused reliability issues. So far I've got the Tempa Flow, reed spacers, coated stock pipe and the Bender "quiet" can. I would like to go with the increased compression if there are no
problems. Premium fuel is no problem.
wont cause any trouble, have done a 100 of them, never had any back. You can run 142.5 mains all the way across, drop needles a half shim, and let her rip, those engines are way fat stock!!! If your gonna run good fuel, you will love the way it wakes it up!
cleansocks
Mine is done with the same jetting as above and was worth it.
SpartaSXr
Mr Viper knows his $hit. My SXr has over 3000 trouble free miles with one layer removed and smaller jetts than he advised. Run with it. You will love the crispness. Dont forget to drop the needles. That alone is worth it.
sockeyerun
Test Dummy
Same here. 02' 700MM,single layer,142.5,2.5 on the needles, But no Tempaflow. 2200 miles.
Soc
WrdAl
Don't try to run the 142.5s with the Tempaflow. Too lean. I'm running 146.3s with the Tempaflow at 300ft altitude (Anchorage).
Does dropping the needles make it leaner or richer at mid throttle?
jetting and the tempa-blow
Guess I should have posted, didnt notice you said had a tempa-blow, you DONT need the tempa-blow with this set up, it will be spot on, and we took a sxr with this set up to Canada last year and it was fine at -25!! have ridden in temps of +40 with it too, still good, but not nearly as crisp as normal, but with this you can sell the tempa-blow to one of your enemies.
water: it leans the mid range, those sx,sxr motors are pig rich!!!
Thanks!!!!!!!!
