Question on clutch offset tools (electric start)
gil7247
Muskegon Michigan
Who sells/ makes a offset tool for electric start models? Most I see are for Non- electric start. Or would I be farther ahead to just buy the regular tool and pick up a spare decent clutch w/o the starter ring to use to set up the engine alignment. Then I could just switch clutches when I'm done. I imagine the normal clutch alignment tools are much cheaper and more readily available. Thanks Gil
Ya that would be an idea. I was just thinkin if I could score an old clutch cheap I could just keep it around so I didn't have to take my ring off and on. If I could find just the clutch without the weights or spring cheap I've got an old spring I could use for the cover. I just need the 2 sheeves spider and cover and they could even be damaged as long as the fixed sheeve was flat or square. I was hoping to find a slightly damaged one cheap if anybody has one laying around? Gil
How about $30 shipped, they are like new condition. I will get a picture for you in a few minutes.
