P85
torelloracing
ct
Ok so I have a Polaris primary but need to know how to tell if it is a p85 that will work on my 01 srx any info would be great ! I am just trying to ride next weekend then will get the yamaha set up but this was free thank you for any help
Measure the diameter and depth of the tapered hole and compare it to your stock clutch. The P85 I wound up with's tapered hole was a bit too shallow so I drilled it a little deeper (it needed to be less than 1/4 deeper) with a 1 1/16 cutter IIRC.
