gina821
How do you remove the primary clutch on a 2002 Yamaha sx viper 700?
staggs65
you need a clutch puller
viperking
You have to take the bolt out, then get a clutch puller for a yamaha clutch and run it into the bolt hole until the clutch pops off
gina821
Will a doo puller bolt work? or i need a yamaha one...
need a yamaha puller
gina821
Alright guys, thanks. Now to finish pulling a dead motor...
gina821
Alright, I tried 2 different pullers, one fat one, and a skinnier one, the fat on is too big, and the skinny one bottoms out before it seats to pull the clutch (if that makes sense). So my question is, how many different Yamaha pullers are there, and which puller is right for my sled?
gina821
Anyone?
viperking
http://www.amazon.com/Clutch-Puller-Yamaha-Part-PCP-6/dp/B006F8TAWU
That's what you need, if the puller bottoms out without popping it you can hit the socket with a hammer to get it to pop
I have only two yamaha pullers, one for the old yp 20 mm large threads and one for the ypz and yxr style smaller 18 mm threads.
09nytro
Just order the right one before you mess your clutch up. Sounds like you have two comit clutch pullets to me. Again get the right one it will come in handy down the road
jasonlmrx
Pack grease or turn the sled on the aside and put water in the shaft and tighten your smaller clutch puller in there(assuming you have the right puller.) that might make the job easier dont over do it tho just to help get you that additional play. im guessing if you the right puller the clutch might be stuck on there for cariouse reasons.. and it is suposed to 'bottom out' thats is what makes it pull it off.
