The Hammer
The light and fuel gage flashes 8 times, anyone have ideas?
Sled it stock.
Sled it stock.
mod-it
With the fuel emblem lighting up, it sounds to me like it thinks it's low on gas. If it's not, then possibly something wrong with the fuel sender?
The Hammer
mod-it said:With the fuel emblem lighting up, it sounds to me like it thinks it's low on gas. If it's not, then possibly something wrong with the fuel sender?
checked float in tank all seems ok, gas tank is full
thats not it
my gaz units its **** too went the tank is full the light blink till the gaz go lower in tank then in stop flashing ...does it flash all the time or all depend the level in the tank
wait ,,,,,,, what.......hahhmodsrx said:my gaz units its **** too went the tank is full the light blink till the gaz go lower in tank then in stop flashing ...does it flash all the time or all depend the level in the tank
The Hammer
Ill pump some gas out and give it a try why not
The Hammer
It was the fuel sending unit was bad if anyone ever has this problem again. 8 flashes
