HELP I got a 2002 SRX 8500km eveytime I go out my temp light flashes 40 time yes 40 time and no pause will stop for 5 min to 15 min and come back on the sled not over heating it run good will do that all night and my dcs light is coming on at full throttle around 90-110km can it be a bad belt making it rev to high not sure what the rev are my tech is broke thanks if some one can help me
if the temp light flashes that much,it is probably over heating.Mine years back was flashing steady when I did some wot pulls....wasn't loosing coolant..but found out the thermostat imploded on me and deformed...it wouldn't open up and let coolant circulate..I opened it up and yep the thermostat was toast..check that first.
hey hey that remember the story i told u to check blue ...........been there done that
yeah it was a few years back..I remember you said you always carry a spare with you..so do I now..lol
thank will check that
hey I just check my thermostat and it broke need a new one thanks
there you go..I wasn't just whistling Dixie you know!! lol..Good you found it.Modsrx helped me when mine was toast and I pass it on to you....always carry a spare one now since I have gone through it,saves on down time when an extra one is in the drawer..
Thermostat Failure mode
I just wanted to write and say thanks, the following failure happened to my 1998 SRX 700s. Back when mine failed the dealer and Yamaha said that they had never seen this failure so I thought mine was the only one, which is highly unlikely!
Back in 2002 my thermostat failed but my failure mode was catastrophic. The thermostat spring and retainer popped free and when they did they cut off coolant flow to the cylinder heads.
Needless to say the light came on for a few seconds until only steam was left then the light went out. A friends son was riding it at the time and thought that the overheat condition corrected so he road on for about 200 meters when the engine seized.
As we tore down the motor we could not ID the failure mode and although many parts had failed there was no smoking gun that started the failures. I had gone home and ordered all new parts for the rebuild ($2,800+ for everything but the crankcase) but was perplexed because of our inability to diagnose the root cause.
As the rebuild started (my buddies son was performing the work, he was 28 and a ceritfied mechanic) I asked my friend to check out the water pump, when he did he found the defective thermostat.
bluewho
Buy the short yamaha one instead of the long neck style and it wont happen again.Went thru 2 myself before i did this.
bluewho said:Buy the short yamaha one instead of the long neck style and it wont happen again.Went thru 2 myself before i did this.
short one ???that goes in what sled???...it happend went the thermostat try to open to mutch because of the coolant being to hot and then it pop off....
bluewho
I cant say mod it dosent have that long neck like the srx style mabie a exciter?You know the neck were the probe sits inside of.
