Has anyone tried to add a extra set of wheels using a set of the factory boggie wheel brackets that bolt to the rails?
I was thinking about adding a wheel between the double wheels and the rear wheel
bluewho
If you put them along the outside of the rails it should work.The control arms that run beside the rear shock dig into the wheels if you have the axle with 2 wheels mounted on it and put in the middle of the rails.You might be able to mount them farther back or use smaller wheels.
bluewho
Great picture
I was thinking the same spot just on the outside of the rail
bluewho
The centre ones got chewed on the axle with 4 wheels.I didnt think they would because of the higher stops if you can see that,but they did.lol
I just found a post where someone but 5 3/8" wheels instead of 5 1/4"
Maybe that would be the answer
orchie18
I have polaris wheels in the middle and aftermarket oversized bilet everywheres else. rolls across the garage floor with out scratching the floor all to heck.
