robxcr
Any problem using a 01 srx head on a 98 srx rebuild? Have two good one from 98 and one from 01. The same? Thanks.
no, you can use 98 heads on a 01 cylinders to give you less compression.
if you use 01 heads on 98 cylinders, you will have more than stock compression.
I have some 98 heads if you need one, I just had to buy a 01 head for a sled I was working on.
robxcr
Any chance you need a cylinder for a 01 srx, i got that as well as part of the deal, and couldnt use that either. Just waiting to hear from a guy close to me about a head, and will then call you to get one if he cant help me.
Thanks.
Thanks.
robxcr
What could happen if you ran one cylinder like this?? Been doing that for a while and it runs great. If im going to bugger it up i would like to quit doing that though!!
