1991 Exciter II Throttle Play Adjustment
onehotpocket
Minnesota
I was riding my Exciter yesterday when the TORS light started coming on. After messing around with various things for a while I found it was because I didn't have enough throttle play - cable is too tight causing throttle to stick slightly open.
So I have figured out that much, but I'm not sure where the adjustment is for the throttle play on these sleds. I can see two separate adjusting nuts (each just about 6 inches up the cable from the top of the carbs) but I'm not sure if those are the ones I want to adjust or if there is a single adjustment for both carbs somewhere else on that cable? If someone had a picture that would be great as well.
Thanks,
Dave
