Picked up a set of benders a couple of weeks ago , just got new gaskets and jets 50/150s ride at around 1000 ft. Weather is getting warmer (9deg today) and sled is running great , stock other than reeds . Searched through the forums and cant seem to find much on a clutch setup for me , don`t want to waste last bit of winter trying out testing clutch setups. The one i did see used 8-ca weights with no rivets ,o-p-o primary spring , stock secondary spring and helix @ 70deg wrap. Any help would be awesome , tks .
Check out the tech pages for clutch set ups.
if there is i cant find one , that one i found from a old post 2003 . Everything else is higher elevation ,gearing changed , or aftermarket helixs
I have the bender paperwork for those pipes, send me a pm with your email and I will send the info to you.
thanks srx1000 , just what i was looking for
YooperMike
I believe these were some of Turk's setups for the Benders, didn't search to verify but had them written down on a scratch sheet of paper:
#1)
150 main jets
52.5 pilots
raise needles 1/2
89L weights with a 2.4 gram rivet
14.5 mm rollers
y-s-y primary spring
52/44 helix
green secondary spring at 70 wrap
#2)
Home elevation
52.5 pilots
150 main jets
raise needles 1/2
8cr weights with 4.5 gram rivets in both holes
54/44 helix with green secondary at 70 wrap.
high elevation
62.5 pilots
137.5 main jets
drop needles 1/2 from stock
8cr weights with 3.6 gram inner rivet & .8 gram in tip
green spring with stock 43 helix at 80 wrap
20/40ish gearing
#3)
150 mains straight across
50 pilots
Raise needles 1/2 right across
14.5 mm rollers
89L weights with 2.4 gram rivet
52/44 helix with stock secondary spring at 60 degree wrap.
#1)
150 main jets
52.5 pilots
raise needles 1/2
14.5 mm rollers
52/44 helix
#2)
Home elevation
52.5 pilots
150 main jets
raise needles 1/2
high elevation
62.5 pilots
137.5 main jets
20/40ish gearing
#3)
50 pilots
14.5 mm rollers
A couple of bucks
Go to....
1.TY Home
2. Technical pages
3. Snowmobile tech
4. Clutching & Jetting
Here is Turks set-up for that particular sled w/ Benders
97-99 SX700 w/Bender pipes
51/43 Helix, 89-L weights w/2.4g rivets, stock springs, and stock gearing. Jetting: 150 mains.
1.TY Home
2. Technical pages
3. Snowmobile tech
Ya i seen lots for sx/srx/sxr, not the MM , i beleive the MM gearing is a bit different and my track is an 1 3/4, Anyway thanks for all the help got lots of info to get going again.
A couple of bucks
There are 2 setups for a 97 MM under the TOTALLYAMAHA USER CLUTCHING CHARTS. Boondocking setups.
1. TY Home
2. Technical section
3. Snowmobile tech
4. TOTALLYAMAHA USER CLUTCH SETTINGS
1. TY Home
3. Snowmobile tech
