07 Venture Squeeky Belt
dave3406
Fort McMurray
I have a 2007 Fan Cooled Venture with only approx 200 miles on it. The belt has recently become very squeeky when the rpm's raise above idle or even if a little pressure is applied to the belt (by hand) while the sled is idling. I have removed the belt, cleaned the clutch with fine sand paper to ensure it is smooth all around, and replaced the belt with a new one but still have the same issue. BTW, the old belt did not show any visible signs of abnormal wear. Has anyone encountered this before of have any advice?
^X2^ your secondary should have a little side to side play. You can pick up the flat stock style alingment tool for like 20 bucks or put a straight edge on back of clutch's and measure off set with a tape measure. If the motor is slightly crooked gap will be bigger at front or back of clutch and belt will squeal like a stuck pig!
