how those plug look
modsrx
canada,qc
first 2 midrange and 2 last are wideopen at -7c ;)!
Looks fine. How does piston wash look? What MPG are you getting? Why do the Habs suck worse than the Leafs?
can't see no wash ...since the cylinder was ported the wash was gone ..... those plug are running with 160 main jet stock needle setting .......
you should get some e3 plugs. my triple seems to like them. no noticeable gain in hp but slightly more mpg
YAMMIEGOD3:16 said:
YOU SCREW WITH THIS SLED YOUR ASKING FOR TROUBLE. THOSE PLUGS ARE NICE. 3:16 (yammie tony)
didnt want to play with it ..thnx tony ...i just drop needle and sled seem to work perfect ... ;)!hope it will be safe in cold temp
SRX_700 said:
So third clip with both shims below?
yes but keep in mind that the 160 main jet will change the middle circuit too ....its start to be a fat jet ....
staggs65 said:
probably vented to the airbox. I've got 165s in my mrviper ported viper right now.
they are not vented into the air box ....nothing have been change to the vent of carb..just pretty aggressive porting ... :winterrul
Got nothin to do with spark plugs, but that Viper looks bad a$$ from the front!
