nicksxr
What did you guys torque your heads to after you did the head gasket mod. I torqued mine back to the stock settings and had cooland leaking up past a couple of the studs??
thanks
thanks
did you check the tech pages on TY ??? http://www.totallyamaha.com/snowmobiles/aaTECH/Simple_Specs.htm
nicksxr
yep, thats the spec that used(actually got it out of the book). with brand new gaskets, and still leaked. I was on the trail, so it tightened down by feel and it went away, havn't had a chance to see what its at.
billcos
Had my heads off twice used the stock torque 8 ft/lbs firsrt then 17 to finsh warm up sled let cool then retorque no leaks
