97 VMax 700 Motor Question
I've never done it, but I would think as far as motor mounts go the worst case would be you'd need to use the mounts from the Viper motor. Buuutttt.... that would be the least of your worries, you need to swap all the wiring and electronics as well.
Coming from the guy that just covered every milimeter of my harness I think that would be the easy part. Anything is possible. Find some empty engine bays and measure away. Keeping in mind primary lining up with secondary is the only thing you really cant get around. If the motor mounts are identical but primary offset is off by 1/2 inch its alot of fab to get that 1/2 back. Thinking you have to play with gears as well. Would definately be a sleeper look like a sx and run like a viper!
