justin1620
I am in the process of fixing my crashed SRX 700. The handlebars I bought off eBay have handlebar hooks but for some reason the throttle side hook is upwards and not downwards like it should be. I removed the hook so I could face it down but I cannot for the life of me remove the other part that is inside the handlebar. All I have to do is remove the inside part but I am not sure how to get it out.....I already took the Allen head screw out and removed the hook portion....can't get the other part out
Any suggestions? Thanks
Any suggestions? Thanksjustin1620 said:I am in the process of fixing my crashed SRX 700. The handlebars I bought off eBay have handlebar hooks but for some reason the throttle side hook is upwards and not downwards like it should be. I removed the hook so I could face it down but I cannot for the life of me remove the other part that is inside the handlebar. All I have to do is remove the inside part but I am not sure how to get it out.....I already took the Allen head screw out and removed the hook portion....can't get the other part outAny suggestions? Thanks
If I'm not mistaken, they work just like a bicycle bar that uses two ramps/wedges that when tightened with the allen screw the wedges are driven together and forced into the I.D. of the bar.
Re-install the allen screw a few turns in but leave it loose, then tap on the screw to force the inner wedge away from the outer wedge.
TopGunnSrx
Screw the bolt in a few threads and give it a yank.
