Yamaha blue touch up paint
justin1620
ON, Canada
Has anyone ever found a good substitute paint code (auto body paint code?) instead of buying the expensive duplicolor deep purplish blue metallic spray cans? Almost $40 by the time I pay for shipping for 1 can....I was also looking at a touch-up brush in ford, gmc, etc...see lots of blues but not exactly sure what color is a good match.........
I got this out of the tech section hope it helps. I had the local paint place do a color match worked out great and could use the cheaper shop line paint instead of the name brand PPG ;)! ;)!
Sikkens Brand Blue Metallic with Pearl clearcoat code # 622 D5
Trailing arm silver:
Navistar silver pearl met.
Dupont m1930k alt. 0
Ohlins shocks yellow is Dupont 218a alternate 1
Yamaha Blue Pearl, ...this is an official Yamaha color on PPG color charts, although you can take the following recipe to any auto paint supply outlet. By: srx_eh
PPG MIX @1/2 PINT:
DMD624 58.2
DMD675 100.7
PRL92 123.9
PRL90 132.7
DBX1689 267.3
I bought both colors for $10 at Murray's Auto located in lower Michigan. Make sure you shake the color before using. Both colors are real close. By: viper7mi
Dupli-Color - manufacture
blue - HA 00980 Electron Blue Pearl B95-P Honda
silver - 77-00974 Starlight Silver (M) Clear coat 2001
The new Dupli-Colors come in a cool scratch and fix 2 in 1 pen type dispenser on top with a brush inside. The pen part fills in small spots great.
