1sickviper02
Is there any way to get my viper to have more weight transfer for better hole shots without having to buy transfer rods? i have the stock rods set at max transfer and it doesn't throw any weight back, it just spins like hell, seems like it's still heavy on the skis..anything i can do about this?
mrviper700
VIP Lifetime Member
loosen up the front limiter straps, and set the full rate adjuster on soft, you can even reduce the spring preload on the center shock, this will get the front up when ya gas it if the track hooks up, play with the settings till ya get it where ya like it, the more you let out the straps, the less ski press. you have and vice versa.
1sickviper02
i'm going to have to try that because everyone is getting my by atleast 2 lengths out of the hole...thanks for the info
SRX_Dave
- Sep 2, 2004
Hey MrViper, I've always heard that you wanted to increase preload on center shock to give more rock back or seasaw effect as well as let the limiters out. I've never tried it though b/c I was afraid hyfax wear would be harsh.
Dave
Dave
I would think more preload on the center with longer straps and softer rear shock....also take the washer out of the top of the transfer rods...
