viper questions
97mm700
Makkovik Labrador
hey, im wondering what throttle cable extention is best for the yamaha, and if u can get them, for the oil cable also, i got 7 inch raisers with pro taper bars, and the pivot adaptor is same high as if you bolted on normal bars. also i want to drop 1 tooth on my top gear and add one on the bottom gear so its same as droping 2 teeth in the chain case, but i dont want to mess up the rpms, she goes at 9300 now, and this is what she got its a stock bore stroke 696cc triple mild trail port, cpr tripple pipes/tripple silencer. cpr head mod to even out and lower the compression. vforce3 reeds with 165 mains 52.5 pilots heel clicker clutch kit primary with a custom cut 52/40 helix in the secondary. 20/40 gearing with a 70 link chain. 9t antiratchets. extended to 136" with a 2.25 finger track cut to 1.75" . boss highrise seat with optional led light and rear storage. 3" handlebar risers with a stock mountain viper grab bar and there is a variflow installed in the airbox. if i done that will she be alright? even dorp 1 tooh on the top gear would be good enough, she hauls *** to much where i got the trasfer kit taken off for wheeling.
