1000cc big bore
02ViperLT
NH
Has anyone tried the price performance 1000 kit for the Srx or viper? Any thoughts on it?
staggs65 said:
should be able to find plenty of info here by doing a search. been discussed in the past
Ya I did that didn't find any info on it just one mention of it. But thanks for your help.
Seems to me I remember reading a post on another site some time ago from Jeff Simon (CPR) where he talked about one of those kits making around 225 to 230 horsepower. Good but not great for 1000cc's. They may have improved since then. Just bring $$$.
Wow, the performance world has certainly come a long way when you can say "only" 250 horsepower! I believe much of the reason for the lower numbers comes from the smaller crankcase volume of the 700cc motor compared to the bigger (starting out) 800 and 900 engines that the srx is being compared to. Not to mention continued development on those other engines.
I was thinking the same thing...WOW!...."Only 250hp"!
I too think the cases have a lot to do with this...if you notice on most big number SRXs they take tthe webbing out below the piston and above the crank like a more conventional crank case. The Ski Doo Mach Z tripple cases have much larger boxes for their larger reed cages....now if a person were to cut those off of a ski doo case and graft them on to a 1000cc srx's cases......Hmm
I think I may go with the hauck big bore kit. Seeing I mostly trail ride and I just looking for a little more on the throttle.
