gil7247
I don't have a picture to show but I'll describe it the best I can. I am rebuilding a 02 Viper ER in which the center rod bearing went out. I have cleaned up all the cylinders and will be replacing the center piston ,although it wasn't servely damaged. My question is on the center cylinder after cleaning with a scotchbrite pad there are 3 verticle lines (more like very small indentations then scratches. running from the ports to the head. There is no residual alum. in the bore. just these lines or indentations. Would this cylinder be safe to reuse or should I buy a new one. The bore is shiney and you can still see the crosshatch pattern in the surface. Thanks for any advice.
Gil
Gil
viperking
Can you post a picture?
YAMMIEGOD3:16
I SAY YOU WILL BE FINE. IF YOU CAN RUN YOUR FINGER NAIL OVER THEM WITH OUT FEELING A DIFFERENCE, NO PROBLEM. 3:16 (yammie tony)
gil7247
Unfortunately my camera isn't that good, they don't show up. They are not sharp and only a few thousandths deep if I had to guess. A fingernail doesn't catch as they are smooth, but if you run your finger over it cross ways you can barely feel it. Thanks for the help guys. Gil
staggs65
YAMMIEGOD3:16 said:I SAY YOU WILL BE FINE. IF YOU CAN RUN YOUR FINGER NAIL OVER THEM WITH OUT FEELING A DIFFERENCE, NO PROBLEM. 3:16 (yammie tony)
X2, run it
viperking
yup sounds like it should be good to go
ottawaair
Gil, I think that cyl. Should be fine. I would run a quick hone on all 3 of them to help the new rings seat in.
ottawaair said:Gil, I think that cyl. Should be fine. I would run a quick hone on all 3 of them to help the new rings seat in.
X2 Get it honed and run it!!
