SRX clutching for 6000 - 7000 ft
srxhair
Ardrossan,Alberta
I need to reclutch my 01 SRX 151 for up to 7000 ft. I had been using the specs for a 98 mountain SRX; pink silver pink spring, 8DN-00 weights with 10.3 outer and 13.3 inner rivets and 14.5mm rollers. The 98 setup worked well until my clutch blew destroying 1 of my weights. I have two sets of 8DN-20 weights that I would like to use. The 01 SRX clutching spec for 4500 -6500 ft is; yellow white yellow spring, 8DN-20 weights with no outer and 10.3 inner rivets, I will use 14.5mm rollers even though the spec is 15.6mm. My gearing is 19/42 with 8 tooth drivers. Do any of you have any experience with this or a similar setup?
