bADa$$ SRX
My buddy just bought a '99 srx 700, 196 studs(pretty worn), stock track, everything else is stock except for transfer rods, he weighs 200 lbs. i have a '99 Srx 600, 196 studs, stock track, minor clutch work, gutted airbox, i weigh 170 lbs. Do i stand a chance? If not how much faster are the 700s?
he should pull away from you easily because he has the extra horsepower.
They seem to be a whole lot faster. Had a 98 600 and now I have a 02 700.
But then again, I have clutch work on the current sled. But it's like a 20 hp diff or something like that.
shadow44
My 99 700 would radar at 114mph on hardpack most days...I saw a 98 600 same mods as yours run 106 in the same conditions ( running 2000ft )..my 99 had minor clutching and 144 studs. Sort race would be close but I'd put money on the 700 after 1000ft
Devilin AblueDress!
Your mods will help but I give it to the 700. Might be close for the first couple hundred feet. I have 98 srx 600, 2X99 srx 700 and 2X00 700 srx. I picked up a 98 600 srx hood and am thinking about putting it on the 99 700 just to hear the guys squeal about a 600 srx whooping them! You could swap out your top end and razz him endlessly how a 600 spakned him!
bADa$$ SRX
well finally lined up today and i jumped him off the line by about two lengths, by the time we hit 30 or so i looked back and started walking away to about 7 lengths and held em till about 110 mph, finally got my clutching dialed to a T so i think that helps a ton but was still suprised none the less!
staggs65
yeah somethings wrong with that 700. not taking away from your clutching work but if that sled was right it shouldnt end that way.
Devilin AblueDress!
Um....yeah what staggs said. Sleds are basically identical with you being down a 100cc and 30lbs. Even with 700 in factory trim running as it should you should have had your hands full keeping up. As stated earlier in this thread I have a 98 srx 600 and a few 99,00,01 srx 700's.
