venture rails
madmark
Neenah wis
Like to know if i can use the rails from a venture and the all the other parts from a 121 skid and shocks from a xtc if it will bolt into a venture or are the all the arms are different
you can use all the arms and shocks. The differences are mostly in wheel placement up front and the rear scissor is mounted several inches back further in the tunnel. I have a set of venture inner braces if you are doing this and want to reinforce the back at the same time have inner braces. Some guys just move the small ones back.
if you go this rout, check out my thread below, there is a post in it to show you where to better place the front wheels on a 136, you'll never need to replace slides again.
also, you will want to use your side arms, ventures don't use any bushings.
venture rail
thanks you sir for the infor just picked up a 98 sx that hit a tree on the left side and a 99 venture that have a blowed motor and missing the skid and was hopeing that i could change that rail and install into the venture and you conformed that thanks again sir for the infor
