Aircraftman
Is there a carb boot from another sled anyone knows of which will allow 38TMX carbs to be installed on a SRX? any help would be appreciated.
Kris
Kris
staggs65
I believe its the Phazer boots some guys use but I've run 38s on my 780 for a few years now with the stock boots without issue
madzx2
i also rum my 38s with stock boots with no problems.
Aircraftman
just stretch out the stockers. Any year Phazer boots? Any help on the baseline setup as far as jetting, needle, etc?
Again thanks
Again thanks
madzx2
I am running the stock jetting from the mach z 800. It ran really good yesterday on the water. My main s are 320.
Aircraftman
thats about what i was guessing. somewhere in the 400-430 range. What needle are you running or would you happen to know the stock needle on a skidoo 800 38tmx?
Aircraftman
Heard a 6HDY35-58 out of a skidoo would work good on a modified motor with 38 TMX but cant find a skidoo part number or cross reference chard describing needles.
madzx2
All I know in my case is i'm running all the stock brass and needle from the 2000 mach z 800. I still need to fine tune
I have the larger boots from the twins, you can use a boost bottle with them or just put copper plugs in them.
Aircraftman
cool. any specific years or models to get the boots from or you have any to sell? I would like boots for stock 36's or bigger. preferrably 38's.
Thankyou
Thankyou
madzx2
needle jet 327-O-2
needle 8ADY-41
pilot 50's
Main 310's
this is what im running on my ported 700.
needle jet 327-O-2
needle 8ADY-41
pilot 50's
Main 310's
