tofastSRX
Installing A Venom Kit On An 02 Viper Non Electric Start Model It Says To Set The Viper To Srx Specs For Center-center And Offset But They Both Have The Same Spec 268.5 C-c And 15mm Offset For Non E Start
ottawaair
Should b easy then.
tofastSRX
I Was Just Wondering Why They Would Say To Ajust To Srx Specs When It Is Already The Same ? I May Phone The.any One On Here Ever Dal With A Venom Kit On A Viper? I Have Done A Couple Searches
staggs65
does the venom kit come with a torque limiter? that might be the differnce. My sled pro clutch alignment tool has washers that you use on non-torque limiter sleds to compensate for how the clutch alignment will be under load. just a thought, not sure if thats what it's all about or not.
