srx dual headlight
MBllnr
Ohio
Ok I will say again sorry... But is it worth running a dual bulb head light in a 98 srx? I have all the parts to do it now but I am not sure if I should bother. When I say parts I mean the pod, light assy, and wires. I do not want to change stator or dig into anything like that. So are dual 35 watts as good as a high and Lo light?
Mike
They are if you buy these. http://www.rockymountainatvmc.com/p/43/72/221/1155/-/-/826764/ The reg or china ones wont cut it. Now you will have 120 watts of output and only draw 5 extra watts vs the single stock. Also add the rear led taillight!! It alot better just due to the better lens design. Here is the led-https://www.denniskirk.com/bluhm-enterprises/1157-dual-function-led-taillight-bulbs.p22551.prd/22553.sku
I found with the dual headlight the light output was much wider than the single. Also it wasn't any dimmer with the 35's vs the single 55/60.
X2.done to mine yrs ago the two 35w-35w
