'00 SRX crank in '02 viper cases
'02viperman
Northwest NJ
Was thinking of trying to put an "00 SRX crank into '02 Viper. Does anyone know for certainty that this will fit? It appears to me that the internals are exactly the same except for the counterweight design. All SRX crank parts #s are the same as '02 Viper's, such as rod bearings, rods, middle bearings, seals, etc. Has anyone done this in the past if they coudn't find the right crank? Thanks!
yes, if you change a couple bearings, you can even put a 98 srx crank in a viper case, which is really a 2000 srx case.
