Hi all, just went for a short ride to test the set-up on the Viper skid I just installed in my 01 SRX. Suspension worked fine but I noticed a peculiar sound from the engine/clutch that only happens at 1/4 throttle/6000 RPM, more or less throttle or RPM and it's back to normal. My 94 600VMax had a jetting update with a lean part throttle condition. Does the SRX have issues with part throttle leaness? or is it something else? By the way the un-updated Viper skid is awesome set to full soft. I actually need to put back some preload to reduce bottoming, that and a little more limiter strap length for transfer and it should be perfect.
blue who
does it sound like a rattle or wat could be belt cover or pipe covers if the moter better pull the carbs or you will be sorry should be no lean spots if they are clean cya
