superpalten
This is my SRX 440 1980 with IFS front suspension.
The history about this sled is in the -80s the previous owner of the sled bought a new sled for his wife with IFS suspension and he test the sled and after that he want IFS, but he was pleased with his SRX so he want the SRX with IFS.
He had a lot of money so he payed someone to convert the sled to IFS.
It´s a serious work!
I get a empty chassie later this week with regular suspension, maybe i switch chassi so i have regular front.
NICE! If I send you my address..could you ship it to me..lol
coop99srx
I have a good friend from high school who had one of these that his dad put srv struts and rear skid under . that was a sweet ride and it got a lot of comments from everyone. i think this one has a little more work would love to see how it was done.
superpalten
coop99srx said:I think this one has a little more work would love to see how it was done.
I can show pictures when the engine is out.
superpalten
Here is the chassie that i uses.
Searching for knuckles, spindles and tie rods.
superpalten
Here is some pictures.
superpalten
Yamaha Nutz
looking good keep up the good work
superpalten
Srx
Looks like tight quarters in your work space. LOL
Yamaha Nutz
Do Not Run That Motor With No Clutch Unless You Want To Spend Lots Of Money On It Again ...........that Is The Worst Thing For The Crank The Hard To Get Expensive Pto Bearings Do Not Like It ...........i Have Had To Rebuild Many Cranks Because Of People Doing This ..........does Sound Nice Though .............like And Learn
superpalten
Yamaha Nutz said:Do Not Run That Motor With No Clutch Unless You Want To Spend Lots Of Money On It Again ...........that Is The Worst Thing For The Crank The Hard To Get Expensive Pto Bearings Do Not Like It ...........i Have Had To Rebuild Many Cranks Because Of People Doing This ..........does Sound Nice Though .............like And Learn
Thanks for info but i know it don´t good for the pto bearings, i have only run less than 5minutes att low rpms so i don´t think they are damaged, i have never think to run the engine without clutch att high rpms.
I gonna put the clutch on tommorrow anyway and meassure offset and maybe put the hood on.
Should i use standard offset 270mm / 5,5mm with a Comet 108?
Yamaha Nutz
YES OFFSET SHOULD BE 5.5..........AS FAR AS THE CENTER TO CENTER I HAVE GONE AWAY FROM THE STD YAMAHA 270 I SET MY CLUTCHS UP WITH DEFLECTION OF 1 TO 1 1/4 '' SEEMS TO WORK BETTER I STARTED TO DO THIS WITH MY CUSTOM BUILDS BECAUSE STD CENTERS WOULD NOT WORK FOR TOP PERFORMANCE ...........BUT THE 270 MM IS PERFECT FOR A TRAIL RIDERsuperpalten said:Thanks for info but i know it don´t good for the pto bearings, i have only run less than 5minutes att low rpms so i don´t think they are damaged, i have never think to run the engine without clutch att high rpms.
superpalten
nysrx said:Looks like tight quarters in your work space. LOL
Haha
Just now it´s some plumbing work in the house and things all over the garage.
Not a nice big US garage but it´s fit a car and a Sled sideways then it´s full
