how long do they hold up,along with the bearings.. when should they be looked at.
no problems with this heart of a 98 sx ? cant be bullet proof
no input on this topic,or is it a dead subject?
SWEDE
I know Snow Tech magazine has had several sleds with that engine,something like 10,000 miles total on that engine with no failures.They say the cranks are very rugged and long lasting even when the engines are piped.That says something as it seems alot of sleds are'nt that reliable when modded.When I read this I thought it was good news seeing I have also.I just remembered that in '98 I believe they beefed up the crank bearing,but I understand that there was never really a problem with them though.
seanmurphy26
yes i read the same thing. i dont think that i will have problems for a while
01sxr700
U might want 2 check the crank seals at about 10,000km's. I rebuilt my engine at that mileage due to a broken ring which took out the jug. The mag side seal was in need of replacement, i also replaced the pto end bearing which has an integral seal. A lot more expensive $85 Cdn.
thanks guys that is good news
