74 GPX fuel line ??
sledder1
Turin, NY
Well this is one of those times when I feel really dumb asking this question. I was replacing the fuel tank on my 74 GPX433 and got distracted. Lo and Behold, I forgot where the fuel lines hook up.
There's two outlets on my tank. One to the left while sitting on the sled, and one closer to the front of the tank.
Thanks in advance for the help.
Should be 3 ports on the top rubber boot. Center should deliver fuel to pump. Left side goes through gauge and to the bottom port on the left side. Right is a vent line. It should run forward to the tube that holds down the tank. Then right past the end of the tube then loop up and around to create a circle. The end should be tucked into the slot in the tank tube and be long enough to go back to the left side of the tank.
opsled
depending on the style tank on gpx the main fuel line comes out from the rear of the tank and does and U and snakes through the center of the tank on the bottom make sure you tape the line in so it stays there to the fuel pump then to the T fitting and then to the carbs onthe top you will have 3 vent nipples the center is the return from the filter the left is the return from the sight gauge and the right is the vent if you have the other style then what OP said but the original gpx tank draws from the bottom back corner of the tank
