are the 98 sx 600 twins ac or dc current i need to know asap.
thanks.
thanks.
super1c
Super Moderator
Both, what are you trying to do?
Vmax540
DC is for charging a battery. AC for everything else ?
Turbo. all i need to do is hook up a oil pump and its ready to test fire. but i need to no if the regulator puts out an ac or dc current because my pump is dc.super1c said:Both, what are you trying to do?
super1c
Super Moderator
The stator puts out ac which is what most of your sled will be without a battery. The only clean dc will be a brown wire. Not sure where it will be on your sled. But it is usually in that group of wires up under the handlebars. Also the revers buzzer harness can be dc also and your sled will be wired for revers wether you hav e it or not. They had both so you will need to start the sled and test the current.
super1c
Super Moderator
http://www.totallyamaha.net/forums/showthread.php?t=58664&highlight=brown+wire
Here is a great post on finding that brown wire.
thatk you guys for the help i havnt located the wire yet because i an still mounting the air box but hopfully i can get a test run on the track stand tonight.
