what is the difference in these heads?
staggs65
98-99 heads and 2000 up heads. different cc's
does one build more compression than the other?
madzx2
i believe the newer heads are 24cc and the older ones are 26cc ?
mopar1rules
SRX700guy said:does one build more compression than the other?
2000-2002 heads are the higher comp heads.
mattyg1405
ive seen more than one sled with different heads on them is this normal?
staggs65
..... no!mattyg1405 said:ive seen more than one sled with different heads on them is this normal?
livewire_101proof
nothing i would want, guess it wouldnt matter though if it is someone who had them machined. then they are whatever chamber u want.
mattyg1405
livewire_101proof said:nothing i would want, guess it wouldnt matter though if it is someone who had them machined. then they are whatever chamber u want.
ive seen it twice at the local grass drags, one was a junk , the other an improver ... idk i was thought it was weird when i saw it.
staggs65
probably were machined as livewire stated so at that point it doesnt matter. but to mix em up as they come stock wouldnt be the best choice
