Has anyone ever painted the case, primer + Aluminum + clear coat and if so did hold up doing it this way and also I was wondering does it make the motor run hotter. (trapping heat)
I figured I have this completely torn down so now is the time to make it shine like new again.
staggs65
get it bead blasted
Blast it. Tried the paint and doesn't look very good after a couple of years. Maybe powdercoating it would hold up not sure.
okay bead blast it is, should i put a clear coat after? Also the blaster has black beauty sand in it now will that work or should i just get my lazy *** to the store and get a bag of glass bead?
Thanks guys for all your input.
staggs65
I wouldnt use the black beauty on aluminum it's quite abrasive. I tried the clear coat before and the problem with it is it yellows over time.
Thanks Staggs will grab a bag of glass bead and no clear coat.staggs65 said:I wouldnt use the black beauty on aluminum it's quite abrasive. I tried the clear coat before and the problem with it is it yellows over time.
