Viper clutching vs redhead clutching
SXRider7Hundo
Northern IL
Since the viper and redhead have identical sweet spots (8500), would a bender setup from a 700 XTC be worth a hoot or close for a baseline for my vipers? I know the weights are different but I figured it might be close due to the springs being very close...
I can't tell you for sure but I'm guessing no due to the Viper making a few more hp than the redhead.
you could, but in my opinion if the kit reuses the stock 8ch weights, I would use the stock viper weight instead. As said already, youd need to fine tune the weight but more then likely you can use the springs and helix.
