Can an exhaust manifold be welded?
gil7247
Muskegon Michigan
The exhaust manifold on my project is cracked at the collecter on both sides. can this be welded and is there any special instructions for doing so? Thanks Gil
You wont find many Vipers without at least a small crack. I would just pull it off, clean it up real well, more than likely its cracked even more than ya initially saw. Dont get the heat too high on the welder.
