gil7247
I'm putting an 02 Viper together that I bought with the motor already removed and the oil pump off the cases. I want to make sure I have all the oil lines routed correctly. Does anyone have a picture or diagram showing the correct routing. I do have another 02 Viper that I could pull off the trailer and removed the carbs to see how that one's routed, but it woulld be lots easier if someone had a pic or diagram.
Thanks Gil
Thanks Gil
super1c
Super Moderator
Gil i still have mine all apart. took some pics the best i could for ya. See if that helps. If you need more ill have to tear the carbs out, this is the best i could get fitting the camera down it there. chris
gil7247
Exactly what I need Chris, thanks a bunch. I know I didn't want to screw this up after rebuilding the motor from the ground up. Thanks again Gil
