600srxman
anyone ever run one on there sleds. im looking at the dyna tek DRL300CDI.
i want to put it on my srx
pro116
Lifetime VIP Member
I know guys that are using them on turbo 2 and 4 stroke turbo sleds but all have a non baffled muffler but wa told you cant use them on a baffled muffler because it blows them apart.
600srxman
well i just ordered one so i will get it next week and let everyone know if it works or not .
600srxman
im running bender triple cans . will see how it goes pro116
jabber800
Don't stay on the stutter long! Its very hard on reeds. Been there done that a few times on a V Max 4.
Make sure you post some video's on how they work for you
600srxman
its installed but have not had time to put a video for you needaSRX. way to busy at work. will try for next week for out. thanks jabber for the info
How does it work for ya even without the video ?
Does your sled launch harder and what RPM's does it engage at
Thanks Andy
Thanks Andy
A couple of bucks
What the hoot is a studder box?
A couple of bucks, I know this is arctic cat but cant find nething else with one on there the studder box is when the driver hits the throttle and the engine revs and cuts out before the launch
http://www.youtube.com/watch?v=wvaoW3pz7Iw&feature=fvwrel
wow Andy,that is one nice sounding Cat there..but what does the stutter box actually do..cut engine back..why???
madzx2
It allows a turbo sled build boost before it leaves the line I think?
bluemonster1 said:wow Andy,that is one nice sounding Cat there..but what does the stutter box actually do..cut engine back..why???
I'll leave that answer for the experts all I know is they sound bada$$ on takeoff
staggs65
you also need to make sure they are allowed in the class you run. I dont think they are allowed in a lot of ISR classes
jabber800
On a 4 stroke they use a shudder box to build boost on the line. On a two stroke it allows you to hold the rpm's of the motor electricly at a set point just below clutch engagement, letting you focus on the tree! You then dump or release the studded button and the ignition is allowed to rev up. Problem is the way it works is it miss fires or drops the spark on the engine. It causes some fuel loading and back firing and is very hard on reeds. It can however really improve your consistency on the tree!
extremelyfastmax4
its my opinon but the stutter box i could,nt be bothered to use it , put one on my nytro and i don,t like it , i perfer to have a preset engage ment bring rpms to that and wait for the light , and any body that was using them against me did,ent see any advantage and most of them got beat by old school racing
