SRX 700 plug boots
yamaha700trip
Rochester, NY
i need to replace my plug boots and have read that many sleds they unscrew. i tried to unscrew mine and they dont. do the boots on the srx tripple pull off? any help would be great!
They unscrew....might need to use pliers. I replaced mine with NGK's. I also snipped off a bit of the end of the plug wires to make sure I got a nice connection. Sometimes there's corrosion at the end.
Thanks for the replies. I'll try and unscrewing one when I get the new boots. Hey when u screw the wire in the new boot, do you strip a little of the insulation off or cut cut it clean?
