Dupont Hyfax
tomseal6
Brevort, MI
I did a search and didnt come up with much other then that they were delayed and fears of the duponts being more durable then the track clips.
If anybody has used these, please post your story
Must be a reason they cost $110 a set although I do see the machined inserts.
Are you referring to hyperfax? I have used them, they do wear a ton better than regular hyfax, but if you ride in a area that gets dirt or sand mixed in the snow, they will wear some. In good clean snow they should out last the top end of a 2 stroke motor
