I have a 99 venture which has the same front suspension as my 00 vmax. I'd like to replace the rusty skis with newer plastic skis. Will the single piece plastic 05+ apex skis fit?
if you have all the mounting hardware, they will bolt right on. you will need the bolt, the collar through the spindle, as well as both spacing collars for the offset all from the new skis.
be leery if someone is selling skis without the mounting hardware. the parts will hurt the pocketbook.
A couple of bucks
That thing should have come w/ plastic skis.
