MM70001
Found a set of Power Inc end dump pipes for a red head 700, curved stinger section of these pipes seems rather small diameter. Could somebody please measure their stingers O.D. and post it.Want to make sure these pipes are for a 700.Wondering if P.I pipes for the 600 and 700 had different stinger diamters or both the same?
dont have any at hand, but i can tell you the 600 and 700 used the same pipe configuration. i have benders on my mm and the piping to the stingers isnt overly large.
MM70001
Do you prefer Benders over P.I. pipes?
when i piped my 01 back in 01, the pi pipes were hard to find, so i went with the benders.
overall i am pretty happy with the performance. with nothing to really compare to, i think the workmanship and materials could have used some improvement. read that as i think the material used is a bit thin.
if you keep them clean and coated, they will hold up.
srxman72
Im at school away from my sled but if I understand what you are asking you want the curved part of the pipe at the end where it bends back toward the front of the sled? If so I would say that's about an inch O.D. if that. I don't think you have anything to worry about, these are great pipes.
