136''
780srxgeorge
michign
i didnt know were to post this on a ?.i put on the 136 track on my sled back in march.no snow & bored. now buying a tunnel exton.a buddy of mine said i could use a differant rear heatexchanger like off one of the other 3 makes.if i can't find one of a mmax.a nother buddy has a lot of Poluras & other sleds.just seeing what you guy a doing or done. :letitsnow thanks
piping configuration along with hose size are you only limitations. the rear exchanger hose fittings are easy to cut, rotate, etc for fitment and welded back on in the right hands.
lots of extra time and expense if you arent an experienced aluminum welder.
I run a SX style x changer on mine. It is a bit smaller, and has 3/4" tubing ends, instead of the 1" on SRX. I just used a pipe reducer and a short piece of 3/4" heater hose. Never had a problem of overheating in last 2 seasons. I think I have another one on the shelf if interested. PM me if so.
You have an SRX?
If you have an SRX you could look for a Mtn SRX extension or order a new one if they are still available. Advantages would be the fact that it would accept your stock SRX cooler which has the correct size tube on it and has far more capacity than an SX or Mtn Max cooler. Another advantage is the correct color to match your tunnel and direct bolt on fit which is always nice. Just some thoughts....I've done it just about every way possible.
Madmatt
yea its my srx.iam going to oder the tunnel-ext from tracks-usa.i looked on the oem-parts diagram on viper & sx & thay are the same accept one was angled a little diffrent & sx had 3\4 ends like ottawaair said.i can use the stock heatEx on it?. or a mountian cooler would be better?.if i need a mountan cooler will any body got one dirt cheep lol.thanks guys for the info.
I used an extension off of a Mt viper I believe and I cut like 2-3" of the back and am using the srx exchanger
when i get the tunnel-ex in i'll have to look at it & see.& go from there. i do have the sx-r viper rear skid +viper rearbumber.a little fab sounds like.thanks for the info guys cant wait to get started on it.
