i just put 54 gram ac weights in the clutch. the weights are a little bit thicker than the yamaha weights which is causing them to push on the rollers. the clutch is slightly engaging now even when the sled isnt running. i can roll the motor over and the sled moves forward. would it be possible to shim the clutch a little to take tension off the belt?
