02 srx speedo gear.
amatosrx
VIP Life Member
byron center mi
Does the 02 have the same speedo gear housing as all the rest of the srxs . I got one is the shop with a triangle stlye one. It does not look stock.
Pete, i have a viper holder for the bearing just has a extra stud on it that can be removed then will bolt up to your speedo drive , if you want it you can have it.
