new to me 01 srx
franklin
fredonia pa
I just bought a 01 srx with 4500 miles on it for $1200. I am wondering if I should be looking for any specific problems. Seems to run fine and I have a mono shock to put in it
Wow great buy check your pvs skid brg clutch her up and hang on. Damn I am jealous.
Clean carbs, put fresh fuel in tank when ready to run, clean and adjust power valves, grease all zerk fittings with low temp grease, change plugs, inspect belt, clean clutches and check offset, check track tension, inspect hyfaxes for wear, change chaincase oil, and inspect bearings.
So just the normal stuff. I will need a stock windsheild and I think I should put on a skid plate If anyone has any of those parts let me know. Thanks for all the info
