What are you guys using to measure the spacing on the oil cable?
Fro
You can use a metric wrench with the same measurement and hold it up to gap the cable.
staggs65
I just use a measuring tape, the manual lists the ranges in both american and metric, and after the initial rough set-up you're adjusting to the actual mix ratio not so much the measurement.
I bought a 5 $ palm sized brass looking vernier caliper at Home Depot. It's been pretty handy for many things. And it's metric.
calipers
